The device must capture the destination address from the first config transaction it receives and store it for use in outgoing transactions. Since PCIe is actually point-to-point, not a bus, a device only receives config transactions that are intended for it.
Means when RP send the configuration first read or write transaction to endpoint, the endpoint save the bdf set in config read/write transaction and use it later.
How can the user logic obtain the bus number and device number from the Agilex R-tile AVST PCIe IP?
- 3 years ago
Hi Jeff,
In P-tile, the bdf is available in tlp config, but not in R-tile.
the RTL is encrypted, Hence not much information I can obtain from that.
What I get from the official release document for R-tile AVST will be.
https://www.intel.com/content/www/us/en/docs/programmable/683501/22-3-7-0-0/about-the-r-tile-streaming-fpga-ip-for.htmlbus#, device# are discovered by RP during enumeration process, only the RP host side can read the bus#, device#
Detail, you may refer to B. Root Port Enumeration
Hope this answer your question.
Wincent_Intel
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wincent_intel
