How can i use Quad SPI to talk with Flash memory ?
I am trying to access Flash memory (MT25Q128) by using Quad SPI Ip (AS x4).
I am driving Quad SPI from PCIe. But i didn't understand the sequence to follow from IP document. Quad SPI does have two ports (avl_csr & avl_mem). Which one i need to drive? when?
Is it possible to store the bit file or data while running the fpga?
what should be the sequence to talk to flash memory?
- Ahmed_H_Intel1
Hi Kishan,
Thanks for this nice question.
The following link show a very useful example for Generic serial flash interface, Please download it and start from there. It is a free example.
- senjd
hi thanks for the reply. i ll go through this link.
- Ahmed_H_Intel1
Please let me know if you need more support.
Regards.
- Ahmed_H_Intel1
The following are a very useful examples show how to deal with PCIe and external memory, please check:
- https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/pcie-avmm-dma-gen2x4-on-chip-and-external-memory/
- https://fpgacloud.intel.com/devstore/platform/18.0.0/Standard/pcie-avmm-dma-gen3x8-on-chip-and-external-memory/
- https://fpgacloud.intel.com/devstore/platform/19.1em1.0/Standard/pcie-avmm-dma-gen3x8-on-chip-and-external-memory/
- https://fpgacloud.intel.com/devstore/platform/16.0.2/Standard/an708-pcie-gen3x8-avmm-dma-with-external-memory/
- https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/an708-pcie-gen3x8-avmm-dma-with-external-memory/
- https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/an708-pcie-gen3x8-avmm-dma-with-external-memory/
- senjd
Hi @AhmedH_Intel ,
Thanks for your reply. This projects are connecting PCIe with external memory. I am trying with PCIe bar4 connecting to Quad SPI interface (CSR + MEM ports). I tried to run following commands on qspi ip using pcie to write something on flash memory.
but i feel i am missing something
control reg [7] = 0x6
control reg [8] = 0x1
control reg [7] = 0x1001
control reg [A] = 0x7C
//WRITING DATA TO MEMORY PORT OF QUAD SPI IP.
MEM [0] = 0x1
MEM [1] = 0x2
On the output side i am getting csn high-low pulses for sometime. & outdata of qspi changes between 0xEh & 0xFh.
Any help appreciate most.
Is there any other registers i need to take care for writing the data?
- Ahmed_H_Intel1
It isn't clear how your system is working, I cannot review just by a piece of code, Can you explain more?
- senjd
Hi @AhmedH_Intel ,
Thanks for the response.
Here is the system level information.
architecture (system) path :
Host driver will write configuration & data from PCIe (Bar4) which is connected to QSPI IP ( avl_csr & avl_mem ) ports.
Sequence i followed is provided from intel quad spi document (page num 26) : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf
proc page_program { } {
global mp operating_protocols_setting control_register write_instr
master_write_32 $mp $operating_protocols_setting 0x00000222 //qspi configuration register (avl_csr port) to select 4 byte enable
master_write_32 $mp $control_register 0x00000101 //qspi configuration register (avl_csr port) to enable output
master_write_32 $mp $write_instr 0x00007034 //qspi configuration register (avl_csr port) for write instruction command on flash memory
master_write_32 $mp 0x00001000 0x1234abcd //qspi memory access port (avl_mem port) writing single DWORD into FLASH MEMORY
Problem statement : I am able to get the address (0x00001000) and data (0x1234abcd). But unable to get the command. Command is required to come first before address & data.
Not able to get the proper sequence from intel. Can you help me out for it?
Thanks in advance
- Ahmed_H_Intel1
Thanks for your sharing, can you please show a screenshot of the Qsys and the Top-level? this will help us.
