hls installation and getting started
I do not know how to set the Visual Studio environment.
Visual studio is on my C:\ drive as a standard install (comunity free version)
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community
Konrad
Hi @Konrad,
Based on the output from init_hls.bat, VS are not found.
And I notice that you are using HLS 19.1, for that it requires VS 2010. (as noted here)
Can you please try installing the VS 2010 pro and rerun the command, and I believe it should work.
Hope that clarify.
Best Wishes
BB
- Konrad5 years ago
I have VS 2010 Pro available at work but not at home. I have installed HLS 21.2 PRO.
Does this need a license or is it OK with Quartus Lite?
From what I have read it seems the HLS Pro is OK without Quartus Pro.
Anyway, when I run the tools they are still pointing to the HLS 19.1 compiler. The init_ .bat ran OK.
regards
Konrad
- Konrad5 years ago
Screen shot of the init_hls.bat
ps. I also have quartus 19.1 installed on my C:\ drive in the standard location...I opened and closed it prior to running to ensure it was the last version run, but the init_hls.bat seems to still pick up on the older version,
Konrad
- Konrad5 years ago
OK it is working. What works for me is...
Run the DOS prompt as administrator
Run the init.hls.bat
Compile the file from the SAME DOS prompt...i.e. don't close the DOS prompt.
Re-run the init_hls.bat every time.
Konrad
