KCMurphy
4 years agoHIgh power consumption in LPDDR3 EMIF interface Arria 10
We have a custom-built board using an Arria 10 as a DSP engine. Part of the design has the Arria 10's hard EMIF controller configured to control a 32-bit wide LPDDR3 memory IC.
The pinout for thi...
- 4 years ago
Solved: The gift that keeps on giving.
RREF_BL and RREF_TL, 2K resistor to ground.
Probably want to revise the docs to make this clearer to people who are not using the transceivers.
AdzimZM_Altera
4 years agoHi KCMurphy,
Is the power supply has been delivered with a correct value?
Do you see a similar issue with other board if possible?
