Hi, I'm trying to make a delay instruction in verilog, I have an output (PWM) and I want to generate another output (PWM1) from PWM but with a delay: i tried this : assign #50 pwm1 = pwm; but it's not working best regards,
thank you!
here it's my code :
module pwm_main (up, dn, pwm, pwm_inv, pwm1, pwm2, pwm3, pwm4);
input up, dn; // PWM control buttons
output pwm, pwm_inv, pwm1, pwm2, pwm3, pwm4; // Five sets of PWM and one set of its compliment
wire [3:0] dc_w;
wire clk_w, oscena_w, dc_clk_w, pwm_clk_w, pwm1,pwm2,pwm3,pwm4,pwm_inv;
assign pwm1 = pwm;
assign pwm2 = pwm;
assign pwm3 = pwm;
assign pwm4 = pwm;
assign pwm_inv = !pwm;
assign oscena_w = 1; //Enabling internal UFM oscillator
altufm_osc0_altufm_osc_1p3 u1 (.osc(clk_w), .oscena(oscena_w));
clk_gen u2 (.osc(clk_w), .duty_cycle_clk(dc_clk_w), .pwm_clk(pwm_clk_w));
duty_cycle u3 (.up(up), .dn(dn), .duty_cycle(dc_w), .clk(dc_clk_w));
pwm_gen u4 (.duty_cycle(dc_w), .clk(pwm_clk_w), .pwm(pwm));
endmodule
/*Instantiation of UFM oscillator for utilizing built in clock*/
`timescale 1 ps / 1 ps
//synopsys translate_on
module altufm_osc0_altufm_osc_1p3
osc,
oscena) /* synthesis synthesis_clearbox=1 */;
output osc;
input oscena;
wire wire_maxii_ufm_block1_osc;
maxii_ufm maxii_ufm_block1
.arclk(1'b0),
.ardin(1'b0),
.arshft(1'b0),
.bgpbusy(),
.busy(),
.drclk(1'b0),
.drdout(),
.drshft(1'b0),
.osc(wire_maxii_ufm_block1_osc),
.oscena(oscena)
`ifdef FORMAL_VERIFICATION
`else
// synopsys translate_off
`endif
.drdin(1'b0),
.erase(1'b0),
.program(1'b0)
`else
// synopsys translate_on
`endif
.ctrl_bgpbusy(),
.devclrn(),
.devpor(),
.sbdin(),
.sbdout()
defparam
maxii_ufm_block1.address_width = 9,
maxii_ufm_block1.osc_sim_setting = 300000,
maxii_ufm_block1.lpm_type = "maxii_ufm";
assign
osc = wire_maxii_ufm_block1_osc;
endmodule //altufm_osc0_altufm_osc_1p3
* Clk_gen module for generating reduced frequencies from UFM Osc
and to make suitable for generating duty cycle data clock and
PWM generating clock
module clk_gen(osc, pwm_clk, duty_cycle_clk);
input osc;
output pwm_clk, duty_cycle_clk;
reg [18:0] count;
initial count=19'b0000000000000000000;
reg duty_cycle_clk;
reg pwm_clk;
always @ (posedge osc)
begin
count <= count + 1;
pwm_clk <= count[10];
duty_cycle_clk <= count[18];
end
endmodule
* Generates 4 bit duty cycle word, each count (6.25%) corresponding to
1 of 16 duty cycle percentages
module duty_cycle (up, dn, clk, duty_cycle);
input up, dn, clk;
output [3:0] duty_cycle;
initial duty_cycle=4'b0000;
reg [3:0] duty_cycle;
always @(posedge clk)
begin
if (!up)begin
if (duty_cycle!=4'b1111) // upward limit
duty_cycle <= duty_cycle +1;
end else begin
if (!dn)begin
if (duty_cycle!=4'b0000) // downward limit
duty_cycle <= duty_cycle -1;
end
end
end
endmodule
* PWM generating module, uses duty cycle value from duty_cycle module
module pwm_gen (clk, duty_cycle, pwm);
input clk;
input [3:0] duty_cycle;
output pwm;
reg [3:0] count;
reg pwm, pwm_temp;
initial
begin
count=4'b0000;
pwm=1'b0;
end
always @ (posedge clk)
begin
count = count+1;
if (count == duty_cycle) pwm = pwm_temp;
else
begin
if (count < duty_cycle)
begin
pwm = 1'b1;
pwm_temp = pwm;
end
else if (count > duty_cycle)
begin
pwm =1'b0;
pwm_temp = pwm;
end
end
end
endmodule
