DChak3
6 years agoHi I have migrated my stratix 10 phy transreciver from 1sg280ln2f43e2vg device to 1SD280PT2F55E1VGS1 device and i found later device phy supports only pma interface no pcs.
Here the transreciver rules are limited to pma no pcs. is there any limitation or need to use any other IP together to make it as pipe interface. Also does this device supports custom pcie controll...
DChak3
6 years agoHi
So in this case if I am using Stratix10 DX device 1SD280PT2F55E1VGS1 which is a P-tile but for transceiver it only shows E-tile transceiver. I cannot use custom controller. I need to use Hard PCIe IP only.
