DChak3
6 years agoHi I have migrated my stratix 10 phy transreciver from 1sg280ln2f43e2vg device to 1SD280PT2F55E1VGS1 device and i found later device phy supports only pma interface no pcs.
Here the transreciver rules are limited to pma no pcs. is there any limitation or need to use any other IP together to make it as pipe interface. Also does this device supports custom pcie controll...
CheepinC_altera
6 years agoHi,
Thanks for your update. As I understand it, you have some inquiries related to the E-Tile Native PHY in the S10DX devices as compared to GX devices. For your information, in the S10DX devices, it consists of P-tile and E-tile only. For the E-tile Native PHY, it only supports PCS-direct or PMA only mode. There is no standard PCS like L/H-tile available. In other words, you would not be able to direct migrate from L/H-Tile Native PHY to E-Tile Native PHY. As for the P-tile, it is used for PCIe or UPI application only. For the PCIe application, you would need to use the Hard IP to leverage the P-tile XVCR.
Chee Pin
