Hi I have migrated my stratix 10 phy transreciver from 1sg280ln2f43e2vg device to 1SD280PT2F55E1VGS1 device and i found later device phy supports only pma interface no pcs.
As I understand it, you have some inquiries related to the XCVR in the S10 devices. Would you mind to further elaborate on the specific Quartus version that you are using? Also, it would be great if you could share some screenshots on the issue observation to ensure we are on the same page.
Thank you very much.
- DChak36 years ago
Hi cpchan
Thanks for the response.
I am using Quartus version 19.3.
Before I used Stratix10 GX device which was L-tile H-tile, so there the phy transceiver has option of transceiver rule as gen3 pipe interface. which is standard as pcs ais included for easy integration.
Now I changed the device (as per requirement) to stratix10 DX device which is E-tile P-tile. So here I can see the transceiver rule is limited to PMA i.e no pcs. So how can we integrate this phy with custom controller as standered is pipe interface for PCIe.
screenshot attached for both device.
