15 years ago
Help: Writing into CVO registers
My system consists of only TPG , CVO and SD-SDI output.
TPG (720x480)>> CVO >> SD SDI output
Using Neo, I can read/write the TPG correctly, but each time
when I try to write into the VCO the software hung.
Does this mean I have to do something on TPG (i.e stop) or put into certain operating mode before I can write into any of the VCO registers ? My goal is I want to be able to change VCO parameters at runtime and view the changes of video image on SDI monitor.
Thanks in advance.
    You should be able to read/write the CVO registers at any time without hanging the system. The only thing I can think of is that maybe you selected the a wrong/bad clock in SOPC builder for the CVO.
    Thanks, Kevin. I will check.
    Since I can read/write the TPG fine, I would think my clock (27MHZ) should be fine.
    Question for you though: At the moment I am only interested in using MODE1 of the CVO, the following two parameters were what I set on the megawizard that I am not very certain about !
    Runtime configurable video modes = 1
    Width of "vid_std" bus = 1
    Are these setting correct?
    Again thank you for your help,
    JIMMY
  • CSoil's avatar
    CSoil
    Hi Jimmy, did you ever figure out your issue? I am having issues with the CVO not getting the mode matched.
