Help with 10G Ethernet Configuration
Hi JShel4,
If you don't care about MAC functionality and processing then you can just use Arria 10 FPGA Ethernet PHY IP like "1G/10GbE and 10GBASE-KR PHY" IP to intercept your incoming data traffic from SFP module and retransmit the XGMII data to another Ethernet PHY IP and then blast out to your backplane.
KR option is available to support feature like "auto negotiation" and "link-training" in case you need it.
dlim
- JShel47 years ago
Hello dlim, thank you for the quick response. I think I understood your point. Please help verify my implementation:
I am attaching two pictures towards the end of this reply --- showing the data paths --- XGMII (for 10G) and GMII (for 1G).
Logically, my Ethernet PHYs look something like this: SFP+ --> 1G/10G Phy --> KR PHY --> Backplane connector
- Line PHY == SFP+ to A10 1G/10G PHY
- KR PHY == A10 KR PHY to Backplane connector
Question: Do you see any issues in the data path - especially for XGMII ... do I need to re-wire for SDR XGMII? (like the table shown in page 137 of the Transceiver User Guide)?
One more question: Any suggestion on how to close timing inside the KR IP? I see timing violations in and around the AN block. For e.g. :
From Node: phys|kr_phy|xcvr_10gkr_a10_0|CHANNEL|rx_parallel_data_native[26] To Node: phys|kr_phy|xcvr_10gkr_a10_0|CHANNEL|AN_GEN.AUTO_NEG|DECODE|dme_dly2[26] Launch Clock: phys|kr_phy|xcvr_10gkr_a10_0|rx_pma_div_clk Latch Clock: phys|kr_phy|xcvr_10gkr_a10_0|rx_pma_div_clk Data Arrival Time: 15.434 Data Required Time: 13.897 Slack -1.537 (VIOLATED)Screen Shots of the GMII and XGMII data paths between the two PHYs
