14 years agoHelp: Windows didn't assign Bar0 to PCie (address mapping is not correct)
Dear all, We changed the Altera Cyclone PCIe DDR2 reference design to our needs. However, it doesn't work. The address mapping is not correct, it doesn't agree to address assignments in Qsys. ...
14 years agoHi Nial,
--- Quote Start --- This doesn't meet timing (with a pcie core clock to pcie core clock path setup failure), although the PCIe user guide says this configuration should work in all '7 devices. --- Quote End --- I've updated the PDF and zip file linked to in the original thread: http://www.alteraforum.com/forum/showthread.php?p=147114 I edited the C4GXSK constraints.tcl script to use a -7 speed grade, and I can confirm that timing fails for that speed grade. I agree that this is inconsistent with the PCIe Compiler Users Guide. I still can't get the Stratix IV GX x8 design to meet timing either. Cheers, Dave
