14 years agoHelp: Windows didn't assign Bar0 to PCie (address mapping is not correct)
Dear all, We changed the Altera Cyclone PCIe DDR2 reference design to our needs. However, it doesn't work. The address mapping is not correct, it doesn't agree to address assignments in Qsys. ...
14 years ago --- Quote Start --- The Cyclone IV GX designs meet timing if you turn on multi-corner timing analysis. Cheers, Dave --- Quote End --- I need to reply about this in that other thread but I have a design which is... CycloneIV '7 Hard IP PCIe core Avalon MM interface with Qsys design flow A fair bit of custom logic, but a fairly simple Avalon interface My logic drives DMA to the host memory using the address translation tables as above 125MHz core clock. This doesn't meet timing (with a pcie core clock to pcie core clock path setup failure), although the PCIe user guide says this configuration should work in all '7 devices. I raised an SR but a project archive doesn't include the *.qsys file, and as whoever handled the SR couldn't open the qsys project they simply marked the SR as closed. :eek: I don't actually need the 125Mhz clock so am using the 62.5MHz option but could have had my fingers burnt here. Nial.
