18 years agoHelp! Implenting a Cmex S-functions into your FPGA
Hello all I was wondering if any one has managed to get Signal compiler in simulink to actually compile and convert your S-function to VHDl. I have completely hit a dead end and cant find ...
18 years agoOh thanks Dabuk, I have read the section 15 times LOL.
But I will send you my MDL files hopefully you can tell me where i am going wrong. It simulates fine and as as converts it to VHDL but it fails on Synth and fitting. The following error is shown in the DSP Report file : Convert Mdl to VHDL : PASSED Synthesis : FAILED Timestwo.map.rpt Quartus II Fitter : --------- Quartus II Map Log Info (10544): VHDL Assertion Statement information at Timestwo.vhd(71): assertion "" DSP Builder - Quartus II development tool and MATLAB/Simulink Interface - Version 6.0"" is always false Info: Elaborating entity "SBF" for hierarchy "SBF:Outputi" Info: Elaborating entity "sAltrPropagate" for hierarchy "SBF:Outputi|sAltrPropagate:u0" Error: Node instance "timetwoi" instantiates undefined entity "timetwo" File: C:/Nadeem_work/Matlab Tutorial/TimesTwo/Timestwo.vhd Line: 105 Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 1 warning Info: Allocated 135 megabytes of memory during processing Error: Processing ended: Wed Feb 20 11:42:24 2008 Error: Elapsed time: 00:00:01 I have Attatched the following:- Timestwo.mdl --- the simulink model file Timestwo.VHD -- the top level entity file used to creat subsystem builder black box timestwoc.txt-- is the s-function. this file has to be renamed to timestwo.c. I realy appreciate you time and look forward to hear from you soon . regards
