18 years agoHelp! Implenting a Cmex S-functions into your FPGA
Hello all I was wondering if any one has managed to get Signal compiler in simulink to actually compile and convert your S-function to VHDl. I have completely hit a dead end and cant find ...
18 years agoThanks Dabuk,
Your hints realy helped me find some info online, but I am still running into some problems. I have done as you said, created a black box using Subsystembuilder block in simulink using a vhdl file containing an entity block. If you have the time i was hoping you could check if Ihave done the right thing. Basicaly Now signal compiler does convert to VHDL but fails on synthesis and fitting. I am not to sure what the VHDL Entity file should contain. Does it only need and entity declaration or also an architecture? If it does need an architecture how am i suppose to wire up the signals... I hope you reply i need desperate help and realy appreciate your response. Regards, Nadeem
