NWein
5 years agoHDMI RX: GXB rx_coreclkin and rx_pma_clk showing 600 MHz instead of 300 MHz (and failing timing)
I have an two-port HDMI RX-only design, with all the RX code copied from the example design. However, apparently there's something I didn't copy correctly because there is a 2x difference in the clo...
Deshi_Intel
4 years agohi,
Other thing that I can think of is the reconfiguration profile of PLL IP and NativePHY IP.
Make sure you copy everything and also review the sdc file.
These are some critical design files that I can think of that will affect TImequest Analysis.
dlim
- NWein4 years ago
I will look through and try to figure out if I somehow omitted any files. Could take a little while; will report back here.
