NWein
5 years agoHDMI RX: GXB rx_coreclkin and rx_pma_clk showing 600 MHz instead of 300 MHz (and failing timing)
I have an two-port HDMI RX-only design, with all the RX code copied from the example design. However, apparently there's something I didn't copy correctly because there is a 2x difference in the clo...
Deshi_Intel
5 years agoHi,
There are 2 different IP that I am referring here.
- NativePHY IP setting
- I can see from your screenshot that you changed the default CDR reflclk from refclk 0 to refclk1 ?
- What else did you changed ? You can slowly cross check back with HDMI example design
- PLL IP setting
- In HDMI example design, there are multiple PLL used to provide clocking to HDMI Rx IP and also NativePHY IP. Some are IOPLL IP and some are fPLL
- The one connected to NativePHY IP should be fPLL.
- Anyway, I advise you to trace back the clocking design connection in HDMI example design and cross check with your own design again
dlim
