NWein
5 years agoHDMI RX: GXB rx_coreclkin and rx_pma_clk showing 600 MHz instead of 300 MHz (and failing timing)
I have an two-port HDMI RX-only design, with all the RX code copied from the example design. However, apparently there's something I didn't copy correctly because there is a 2x difference in the clo...
Deshi_Intel
5 years agoHI,
- May I know are you using Arria 10 or Cyclone 10 GX ?
- Which Quartus version ?
- Some possibility that I can think of that may affect clocking report are as below. You may want to cross check with example design again
- NativePHY IP setting
- PLL setting
- SDC constraint
dlim
- NWein5 years ago
1) Cyclone 10GX
2) Quartus Prime Pro 20.2
3) a) Exactly where would I find the NativePHY PLL Setting? I've looked but can't find anything that obviously connects to the multiply by/divide by problem shown above.
b) I will check again, but all the SDC constraints were copied directly from the example design, as was the entire source tree. Although obviously *something* is different, somehow..
