JLee25
Contributor
5 years agoHDMI Reference Design FR_CLK
Hi all,
I am curious to know the requirement of this fr_clk mentioned in C10 GX HDMI UG, https://www.intel.com/content/www/us/en/programmable/documentation/ezu1511767661589.html.
My question i...
- 5 years ago
HI Johnson,
On 2nd thought, I think you can still connect fr_clk while providing whatever clk frequency that's available on your board. Eg : 100MHz.
I found out more info. It should still works as stated from below A10 HDMI example design guideline doc that explained on fr_clk functionality.
- Free running clock (625 MHz) for primary transceiver reference clock. This clock is required for transceiver calibration during power-up state. This clock can be of any frequency.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-hdmi-de.pdf
dlim
Deshi_Intel
5 years agoHi Johnson,
Your understanding is correct.
This is new feature where we added in latest HDMI IP example design in case customer required quick transceiver power up calibration process.
If you don't have such concern then it's totally fine to ignore it.
- Pls modify gxb_rx NativePHY IP to change default CDR refclk from 0 to 1
- CDR refclk 0 is the FR_CLK that you want to bypass while CDR refclk 1 is the TMDS clk that HDMI is using
dlim
