HDMI Reference Design FR_CLK
- 5 years ago
HI Johnson,
On 2nd thought, I think you can still connect fr_clk while providing whatever clk frequency that's available on your board. Eg : 100MHz.
I found out more info. It should still works as stated from below A10 HDMI example design guideline doc that explained on fr_clk functionality.
- Free running clock (625 MHz) for primary transceiver reference clock. This clock is required for transceiver calibration during power-up state. This clock can be of any frequency.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-hdmi-de.pdf
dlim
fr_clk is the transceiver power on calibration pll refclk source for HDMI Tx and CDR refclk0 for HDMI Rx.
It's recommended to follow back example design to use 300MHz.
dlim
- JLee255 years ago
Contributor
Hi dlim.
Thank you for the reply!
What bothers me is the clock did not exist in the old reference design..
And I have a design following the old without this fr_clk..
And it's not possible to add this as all the clock pins are used.
Therefore would you check if this fr_clk is a must?
BRs,
Johnson
