[HDMI IP] info_avi[112] control bit is assigned to Virtual Pin -> why?
- 4 years ago
Hi amildm,
Good day.
>Will the infoframe packet be sent out when info_avi[112]=1and blocked/filtered out when info_avi[112]=0?
I believe the above statement is incorrect.
Based on the Cyclone 10GX schematic file:
C10gx Schematic file
and the HDMI IP User Guide:
HDMI IP User Guide
when info_avi=1, it will not insert the Infoframe.
With that, the Infoframe packet will be sent out when info_avi[112]=0 (user_pb_2=1, released) and blocked/filtered out when info_avi[112]=1 (user_pb_2=0, pressed) .
Hope this answer your question.
Thank you.
ZulsyafiqH_Intel
Hi amildm,
Good day.
I wish to follow up with you about this case.
Do you still have further inquiries on this issue?
Hoping to hear back from you so that we can proceed for next step.
Thank you.
ZulsyafiqH_Intel
you can close this case, thank you for your support!
