amildm's avatar
amildm
4 years ago
[HDMI IP] info_avi[112] control bit is assigned to Virtual Pin -> why?
Hi All, According to the HDMI Intel® FPGA IP User Guide (Table 24), the info_avi[112] is the control bit, which define whether the HDMI Core insert/filter packets on the Auxiliary Data Port. h...
  • ZH_Intel's avatar
    4 years ago
    Hi amildm,
    Good day.
    >Will the infoframe packet be sent out when info_avi[112]=1and blocked/filtered out when info_avi[112]=0?
    I believe the above statement is incorrect.
    Based on the Cyclone 10GX schematic file:
    C10gx Schematic file
    and the HDMI IP User Guide:
    HDMI IP User Guide
    when info_avi=1, it will not insert the Infoframe.
    With that, the Infoframe packet will be sent out when info_avi[112]=0 (user_pb_2=1, released) and blocked/filtered out when info_avi[112]=1 (user_pb_2=0, pressed) .
    Hope this answer your question.
    Thank you.
    ZulsyafiqH_Intel
