amildm
Contributor
4 years agoHDMI IP - YCrCb 4:2:2 pixels mapping + color depth indication
As for the YCrCb 4:2:2 video format, what's mapping of the pixels on the port vid_data of the HDMI IP (two pixels per clock config)?
Should it be this mapping:
As for 10-bits color ...
ZH_Intel
4 years agoHi amildm,
Good day.
Based on your latest response, you are actually using 16bpc, not 10 bpc.
For 10 bpc it should be as below:
Cb/Cr[47:38], Y[31:22], Cb/Cr[15:11] , Y[10:6].
For HDMI, it receive any color formats from the source which means need to set it from source side.
Basically for HDMI, there's a correlation between bpc setting and TMDS clock. Generally, sending higher bpc setting would mean TMDS clock runs faster.
HDMI IP User Guide
You may refer to the link below for more information:
HDMI Intel® FPGA IP User Guide - 4.3.1.2. PLL Intel FPGA IP Cores
Thank you.
ZulsyafiqH_Intel
