amildm
Contributor
4 years agoHDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
In the HDMI Sink, the DRMI packets are mapped to the Address 0x88 of the Auxiliary Packet Memory Map:
https://www.intel.com/content/www/us/en/docs/programmable/683798/22-1-19-7-0/sink-auxili...
- 4 years ago
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
ZH_Intel
4 years agoHi amildm,
Good day.
I wish to follow up with you about this case.
Did you manage to passthrough HDR infoframe?
Hoping to hear back from you so that we can proceed for next step.
Thank you.
ZulsyafiqH_Intel
