HDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
- 4 years ago
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
Hi there,
Is there any progress with the Design Example?
Thanks!
Is there any progress with my question? I need a response ASAP.
How can I disable the DRMI packets filtering in the Intel's Example Design? The file aux_retransmit.v was in not present among the generated files for the HDMI Example Design (generated for Cyclone-10).
