HDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
- 4 years ago
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
Hi there,
Is there any progress with the Design Example?
Thanks!
- amildm4 years ago
Contributor
Is there any progress with my question? I need a response ASAP.
How can I disable the DRMI packets filtering in the Intel's Example Design? The file aux_retransmit.v was in not present among the generated files for the HDMI Example Design (generated for Cyclone-10).
