HDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
- 4 years ago
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
There is one more issue - then I connect two HDMI IPs back to back (according to Intel's Design Example) and stream video with DRMI to one of the HDMI interfaces (used as a sink/receiver), the second HDMI interface (used as a source/transmitter) sends the video stream with DRMI, which value is 12345678... What's wrong?
Here is the configuration:
Video with DRMI ---> HDMI IF -----> RXTXLink (same as in design example) -----> HDMI IF -----> Video with DRMI=12345678
Could the HDMI IF be configured for forwarding a constant value of DRMI=12345678 ???
