HDMI IP -> DRMI (Dynamic Range Mastering InfoFrame) -> how to derive?
- 4 years ago
You are referring to the Design Example for Arria 10, but I'm working with the Cyclone-10.
Instructions for Cyclone 10 DRMI Filtering are different:
but they are not compatible with the generated code...
The User Guide for Arria 10, which you are referring to, is compatible to the generated code, which I have in my project...
Anyway, I'll set the multiplexer_in0_valid signal to '0' according to your recommendation and let you know whether it works.
Hi amildm,
Thank you for reaching out.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you.
ZulsyafiqH_Intel
Thanks ZulsyafiqH_Intel! Looking forward to your findings...
You can think about the HDMI v1.4 to v2.1 Video Converter. There are two HDMI IPs inside of Cyclone 10 - the first one operates as a sink and receives HDMI v1.4 video stream, the second one should operate as an HDMI source and send the incoming video stream out in the HDMI v2.1 format. So, insertion of the DRMI packets to the incoming video stream is required. How should be this done?
