HBM2 interfacing with the PCI express hard IP STRATIX 10 MX
- 5 years ago
Hi, Sorry for the mistake.
I tried the same and I only can see the 16bits on the address. These address bits are affected by the setting of "Address width of bursting master" of the PCIe IP. I believe the developer hack the IP and change the address width to 30 instead.
If you need, you can change this by modifying the g3x16_hbm2_avmm_bridge_512_0.ip file.
Search for Address width of Bursting Master and you can change the value to 30.
Hi Sir,
Are you able to make any progress there?
Perhaps, I can get the design by end of this month. Thanks.
- rsing1085 years ago
Hi @BoonT_Intel ,
I am currently stuck. It would be great if you could get me the design. Also, if possible can you get this design for 1sm21chu rather than 1sm21bhu? if not then 1sm21bhu is also fine.
Thanks for your help.
