HBM2 interfacing with the PCI express hard IP STRATIX 10 MX
- 5 years ago
Hi, Sorry for the mistake.
I tried the same and I only can see the 16bits on the address. These address bits are affected by the setting of "Address width of bursting master" of the PCIe IP. I believe the developer hack the IP and change the address width to 30 instead.
If you need, you can change this by modifying the g3x16_hbm2_avmm_bridge_512_0.ip file.
Search for Address width of Bursting Master and you can change the value to 30.
Hi Sir,
I thought the AN881 is already a multiple BAR design?
It can access DDR4 and HBM2.
BAR 2 for HBM2 and BAR4 for DDR4.
By the way, you can check the design store and see if any design meet your needs - https://fpgacloud.intel.com/devstore/
Hi @BoonT_Intel ,
A881 in the documentation uses multiple bars but the link to reference design is broken. The reference design I mentioned earlier uses only 1 bar i.e. for HBM.
