HBM2 interfacing with the PCI express hard IP STRATIX 10 MX
- 5 years ago
Hi, Sorry for the mistake.
I tried the same and I only can see the 16bits on the address. These address bits are affected by the setting of "Address width of bursting master" of the PCIe IP. I believe the developer hack the IP and change the address width to 30 instead.
If you need, you can change this by modifying the g3x16_hbm2_avmm_bridge_512_0.ip file.
Search for Address width of Bursting Master and you can change the value to 30.
Thanks @BoonT_Intel for the reply. The difference in size is for the BAM_master address of PCIE IP and not the HBM ip. Also the CHU one has 30 bit address in the reference design and chu has 16 bit address for the same PCIE hard ip+ configuration.
please note the typo in my last comment: "Also the BHU one has 30 bit address in the reference design and CHU has 16 bit address for the same PCIE hard ip+ configuration."
