14 years agoHardware -> Nios II big data transfer
Hello, I'm having questions about how to send a big data buffer from my VHDL Hardware component to my Nios II. The problem with this buffer is that its size can vary from 90bits to 2000bit...
14 years agoI see that I won't be able to use the tightly coupled data anyway so, what about writting a FIFO -> Avalon Streaming interface -> SGDMA -> Dual port Onchip memory (S1 on the SGMDA, S2 on the Nios II Data master) -> Nios II (IOWR/IORD direct access) ?
Or should I rather just write an Avalon master interface -> Dual port Onchip memory (S1 on the Avalon Master, S2 on the Nios II Data master) ? (which would be easier I guess) Thank you again dsl.
