14 years agoHardware -> Nios II big data transfer
Hello, I'm having questions about how to send a big data buffer from my VHDL Hardware component to my Nios II. The problem with this buffer is that its size can vary from 90bits to 2000bit...
14 years agoThank you for your answer dsl.
Could you please explain what do you mean by dual port an internal memory block between my vhdl and my nios cpu? Can I do that with an onchip memory for instance? Thank you.
