13 years agoHard EMIF QSYS generation problem
Hi all,
I'm running Quartus 12.1 on Win 7. I'm trying to migrate my design from "SOPC Builder for Cyclone 4" to "QSYS for Cyclone 5". Because the Altmemphy is no longer suported, I created a UniPhy. But when I generate the design I get the following issue :
Error: s0: Error during execution of "{C:/altera/12.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: s0: Execution of command "{C:/altera/12.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: ]2;Altera Nios II EDS 12.1 C:/altera/12.1/quartus/bin/uniphy_mcc -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../cy4c6_sopc_mem_if_ddr2_emif_0_s0_AC_ROM.hex -inst_rom ../cy4c6_sopc_mem_if_ddr2_emif_0_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_MR0=0101001110011 -DAC_ROM_MR0_CALIB=0101001110011 -DAC_ROM_MR0_DLL_RESET=0101101110011 -DAC_ROM_MR1=0000000000100 -DAC_ROM_MR1_OCD_ENABLE=0001110000100 -DAC_ROM_MR2=0000010000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR= -DAC_ROM_MR0_DLL_RESET_MIRR= -DAC_ROM_MR1_MIRR= -DAC_ROM_MR2_MIRR= -DAC_ROM_MR3_MIRR= -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1
Error: s0: UniPHY Sequencer Microcode Compiler
I found a post http://alteraforums.net/forum/showthread.php?p=151954 claiming the solution is "edit nios2eds/bin/elf2hex, change first line to# !/bin/bash". But for me, it doesn't work. Does anybody got an idea? Thanks is advance.8 Replies
--- Quote Start --- Hi all, I'm running Quartus 12.1 on Win 7. I'm trying to migrate my design from "SOPC Builder for Cyclone 4" to "QSYS for Cyclone 5". Because the Altmemphy is no longer suported, I created a UniPhy. But when I generate the design I get the following issue :
I found a post http://alteraforums.net/forum/showthread.php?p=151954 claiming the solution is "edit nios2eds/bin/elf2hex, change first line to# !/bin/bash". But for me, it doesn't work. Does anybody got an idea? Thanks is advance. --- Quote End --- Any luck on this issue? I am having the same issue, 12.1, Windows 7 64-bitError: s0: Error during execution of "{C:/altera/12.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally Error: s0: Execution of command "{C:/altera/12.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed Error: s0: ]2;Altera Nios II EDS 12.1 C:/altera/12.1/quartus/bin/uniphy_mcc -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../cy4c6_sopc_mem_if_ddr2_emif_0_s0_AC_ROM.hex -inst_rom ../cy4c6_sopc_mem_if_ddr2_emif_0_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_MR0=0101001110011 -DAC_ROM_MR0_CALIB=0101001110011 -DAC_ROM_MR0_DLL_RESET=0101101110011 -DAC_ROM_MR1=0000000000100 -DAC_ROM_MR1_OCD_ENABLE=0001110000100 -DAC_ROM_MR2=0000010000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR= -DAC_ROM_MR0_DLL_RESET_MIRR= -DAC_ROM_MR1_MIRR= -DAC_ROM_MR2_MIRR= -DAC_ROM_MR3_MIRR= -DQUARTER_RATE=0 -DHALF_RATE=0 -DFULL_RATE=1 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=1 Error: s0: UniPHY Sequencer Microcode Compiler - Altera_Forum
I downloaded the DP5 patch. See notes: http://macnicatech.com/quartus-ii-12-1dp5-released/
DP5 includes all DP1...DP5 content. Install on top of 12.1 full installation. Works now - Altera_Forum
Spoke too soon. STill fails
Error: s0: Error during execution of "{C:/altera/12.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally - Altera_Forum
Yes still fails...
OK, I got it !!!
I had non ANSI character in my Windows user name. I create a new user containing only English/American character and, it's working ! That's a good day ! - Altera_Forum
Hi, i have the same problem with Quartus II 13.0 (Windows 7 64 bit) and a Qsys system with a DDR3 controller with uniPHY.. (target board=Cyclone V GX)
I created a new windows user with only ANSI characters (€€™) but it doesn't work anyway... can someone help me? - Altera_Forum
Hi Luca,
(2nd reply) No special characters, no spaces and no "long" path for your Qsys project ! Try to put your Qsys project folder right below your work disk (C:\ ). regards, - Altera_Forum
rebuild the project from scratch.
