NWein
5 years agoGXB stuck in calibration: some new issues
Last year I had an issue where my GXB block (included as part of HDMI RX IP) was stuck in calibration: https://community.intel.com/t5/FPGA-Intellectual-Property/Cyclone-10GX-transceiver-calibration-h...
- 5 years ago
HI,
Your Quartus design is complicated and I may need more time to slowly digest it.
Anyway, I have below 2 extra finding to share with you
- Your Quartus design "device and pin option" setting now set config clock source to internal oscillator instead of CLKUSR pin. This is not recommended as per below KDB guideline
- This 2nd finding here could explained why HDMI transceiver channel calibration stuck after you added in "ehive_dual_pd" platform designer that contains PCIe hard IP
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2016/why-doesn-t-the-gen3-stratix-v-pcie-hip-start-flow-control-initi.html
- You can try remove PCIe IP design module and rerun testing to check if PCIe IP is the culprit ?
dlim
NWein
5 years agoI've since tried a great many different things, all to no effect. Here are some details:
- CLKUSR and the 100 MHz clock inputs should all be stable. Nothing much happening there.
- Yes, I had a problem with my HPDN and IN_5V_POWER signals. I've corrected that now, makes no difference.
- I've updated my reset logic so that a controlled 50 ms startup reset pulse is fed to the HDMI blocks, and everything else gets a 200 ms startup reset. That should give the transceivers plenty of time to calibrate before all the rest of the logic starts up. How long does calibration normally take?
- The clock generators on the board are all correct. I can freely switch between the two FPGA builds; on
- The 100 MHz free-running clock input is fed to (a) a PLL to generate my various system clocks, and (b) the fr_clk input of the HDMI block, that's it. As far as checking things in Chip Planner... I have a terrible time with that tool, if you can provide me more detailed instructions what to do I'd be happy to check all that.
- I can try adding blocks one by one in Platform Designer, although that is quite tedious and will take me a while.
