NWein
5 years agoGXB stuck in calibration: some new issues
Last year I had an issue where my GXB block (included as part of HDMI RX IP) was stuck in calibration: https://community.intel.com/t5/FPGA-Intellectual-Property/Cyclone-10GX-transceiver-calibration-h...
- 5 years ago
HI,
Your Quartus design is complicated and I may need more time to slowly digest it.
Anyway, I have below 2 extra finding to share with you
- Your Quartus design "device and pin option" setting now set config clock source to internal oscillator instead of CLKUSR pin. This is not recommended as per below KDB guideline
- This 2nd finding here could explained why HDMI transceiver channel calibration stuck after you added in "ehive_dual_pd" platform designer that contains PCIe hard IP
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2016/why-doesn-t-the-gen3-stratix-v-pcie-hip-start-flow-control-initi.html
- You can try remove PCIe IP design module and rerun testing to check if PCIe IP is the culprit ?
dlim
NWein
5 years agoAnd just for completeness, here's the Signaltap of channel 0 after the Platform Designer block is commented out of the top level source file (NO OTHER CHANGES). Everything looks great.
