yumada
7 days agoGTS Reset Sequencer IP o_refclk_on_ack
Hi, I am using Quartus ver 26.1 PRO Edition and investigating the GTS Reset Sequencer IP. In the figure below, o_refclk_on_ack is described as a pulse. Is there a specified minimum pulse width for t...
yumada
5 days agoHi CheepinC,
Thank you for the reply.
Since this is not documented, I understand that we should determine it by measuring and evaluating it either in a logic simulation environment or on actual hardware. Is my understanding correct?
CheepinC_altera
5 days agoYes, your understanding is correct. Thank you.
