K606
Contributor
1 year agoGTS PMA/FEC Direct Transceiver Streaming
I have been trying to set up the GTS PMA/FEC Direct on the Agilex 5 and would like to know how to stream parallel data to/from the GTS when the GTS does not expose a AV-Sink/Source on the parallel da...
CheepinC_altera
1 year agoHi,
Regarding your following question about the reset, would you mind to further elaborate on what is referred by o_tx_clkout or o_rx_clkout components?
"Does there also include a place to explain how to connect resets for the o_tx_clkout / o_rx_clkout components?"
Please let me know if you have any concerns. Thank you.
K606
Contributor
1 year agoSo for instance, as you expained earlier in the thread, the component that is sampled by the GTS would be clocked by o_tx_clkout, and the component that samples from the GTS would be clocked by o_rx_clkout.
In a diagram:
Now, there are also resets which I assume are controlled via these components, or am I incorrect?
Thanks!
