Prajwal_RJ146
2 years agoGot stuck during establishing ethernet Communicaton using Quartus prime and Nios software.
Dear Sir/Madam, I am currently working on establishing Ethernet communication between a Cyclone V FPGA (5CEFA7F27I7) and a DP83867IR Ethernet Physical Transceiver IC using Quartus Prime 16.0.0 and N...
tehjingy_Altera
2 years agoHi
Sorry that it made it worst. Going back to your screenshot the sgma error only happens when you enabled loopback. Could you try reverting back before the suggested change.
Is it possible if you share the full log in txt instead of screenshot.
Another thing, on the board are you selecting static IP or dynamic?
Jingyang, Teh
