Got stuck during establishing ethernet Communicaton using Quartus prime and Nios software.
Hi
Sorry that i missed out that the PHY you are using is different from the supported list.
In this case you would need to add in the PHY device into the driver so that the driver could interact with the PHY.
During the initialization you would need to add in the PHY device into the driver using the api "alt_tse_phy_add_profile()"
https://www.intel.com/content/www/us/en/docs/programmable/683402/22-4-21-1-0/phy-definition.html
I went through the datasheet and populated the PHY struct below
alt_tse_phy_profile TEXASDP83867= {"TEXAS DP83867", /* Marvell 88E1512 */
00x80028h, /* OUI */
MV88E1512_MODEL, /* Vender Model Number */
0x23 /* Model Revision Number */
0x11, /* Location of Status Register */
14, /* Location of Speed Status */
13, /* Location of Duplex Status */
10 /* Location of Link Status */
/* Function pointer to configure Marvell PHY */
Jingyang, Teh
