Generic serial flash interface in quad IO mode while running form flash
please check bellow attachment. in that marked register controls the mode selection. once check in your design that register enabled for quad mode or not.
https://www.intel.com/content/www/us/en/docs/programmable/683419/21-2-20-1-1/user-guide.html
Hi Hareesh,
I finally have access to my account again.
I can't view the image in your message above, only the link to the manual.
Keep in mind that I am using version 18.1 instead of 21 that the link points to.
I have tried to set the different configuration registers to setup the IP in quad mode. But my problem is that however I do it, either the IP or the chip is behind on the mode change since I can't change both at the same time. And when they are not configured the same the code does not run from flash.
Rienk
