ALMSlinger
3 years agoGeneric Serial Flash Interface avalon wait request doesn't negate on 4-byte Quad SPI flash writes.
I have targetted following reference design to my board - https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/flash-access-using-the.html
My board uses 10AX057H2F...
aikeu
3 years agoHi ALMSlinger,
Sorry that I misunderstood your previous respond.
I was thinking is it only a write and not read issue if you can run the Read from memory flash ?
Can try to perform write enable operation for the flash first before a write operation.
Can share if there is any errors info logs.
Aik Eu
