IMura
7 years agoGeneric Serial Flash Interface : writing to EPCQ bigger than 256MB problem
I am trying to write to an EPCQL512 using the Generic Serial Flash Interface that I instantiated in my Arria 10 HPS. The problem is the Generic Serial Flash Interface creates the avl_mem and avl_csr,...
YuanLi_S_Intel
6 years agoHi Izami,
Can you try this?
master_write_32 $mp 0x00ABCDEF 0x20000000
Thank You,
- IMura6 years ago
Hi YL
Thanks for the quick reply
Doing that, we go outside of the address span : Quartus gives the span 0x04000000 and Quartus normally gives 32 bit Word address, so in byte address, the span is 0x10000000 (yes in HEX).
master_write_32 $mp 0x00ABCDEF 0x20000000 will write OUTSIDE of this span.
So it wont work.
