11 years agoFrameBuffer: A few easy questions..
I'm porting code that used an old, and very different frame buffer from 2010 IP. I'm having a hard time figuring out which signals map to which ports on Altera's new Frame buffer. See below: (The bigger project takes pixel data from a CMOS board camera and displays it using VGA. The next step will be using the SDRAM instead of the limited FPGA memory using a controller I already have.)
old:Inst_frame_buffer : frame_buffer PORT MAP(
rdaddress => rdaddress, -- IN std_logic_vector(18 downto 0);
rdclock => clk_vga, -- IN std_logic;
q => rddata, -- OUT std_logic_vector(11 downto 0)
wrclock => ov7670_pclk, -- IN std_logic;
wraddress => wraddress(18 downto 0), -- IN std_logic_vector(18 downto 0);
data => wrdata, -- IN std_logic_vector(11 downto 0);
wren => wren -- IN std_logic;
); new: Inst_frame_buffer : frame_buffer PORT MAP(
clock => ?? --: IN STD_LOGIC;
reset => ?? --: IN STD_LOGIC;
din_ready => ?? --: OUT STD_LOGIC;
din_valid => ?? --: IN STD_LOGIC;
din_data => ?? --: IN STD_LOGIC_VECTOR (3 DOWNTO 0);
din_startofpacket => ?? --: IN STD_LOGIC;
din_endofpacket => ?? --: IN STD_LOGIC;
dout_ready => ?? --: IN STD_LOGIC;
dout_valid => ?? --: OUT STD_LOGIC;
dout_data => ?? --: OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
dout_startofpacket => ?? --: OUT STD_LOGIC;
dout_endofpacket => ?? --: OUT STD_LOGIC;
read_master_av_address => ?? --: OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
read_master_av_read => ?? --: OUT STD_LOGIC;
read_master_av_waitrequest => ?? --: IN STD_LOGIC;
read_master_av_readdatavalid => ?? --: IN STD_LOGIC;
read_master_av_readdata => ?? --: IN STD_LOGIC_VECTOR (63 DOWNTO 0);
read_master_av_burstcount => ?? --: OUT STD_LOGIC_VECTOR (5 DOWNTO 0);
write_master_av_address => ?? --: OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
write_master_av_write => ?? --: OUT STD_LOGIC;
write_master_av_writedata => ?? --: OUT STD_LOGIC_VECTOR (63 DOWNTO 0);
write_master_av_waitrequest => ?? --: IN STD_LOGIC;
write_master_av_burstcount => ?? --: OUT STD_LOGIC_VECTOR (5 DOWNTO 0);
);2 Replies
The old one is using a simple dual port memory.
The new one using using avalon streaming interface (as is standard for most IP until recently). You can read the interface spec here (you're interested in section 5). I also suggest reading the documentation from the new IP block. https://www.altera.com/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf Non of your old interface will be compatible. You will need to re-write the interface controller (or use other avalon standard blocks). - Altera_Forum
I see now that a 2-PORT RAM was actually used but just labeled as a frame buffer..
