12 years agoFrame Buffer Parameter
https://www.alteraforum.com/forum/attachment.php?attachmentid=8822 I am using Frame Buffer Megacore. I want to store a 640*480 pixels frame to sdram. As in the picture, I set maximum packet length ...
11 years agoIn the Frame Buffer GUI, there is a place to set read and write FIFO depths and burst target. The UG doesn't specifically call out if these numbers represent "bits", "bytes", "pixels", whatever. Does anyone know? I sort of believe it's defined in pixels so if you set your "bits per pixel" to 8, these numbers would be bytes. Sound reasonable?
