fPLL Arria10 powerdown does nothing
- 5 years ago
Thanks for your update. Regarding your latest observation on the PLL powerdown, as I check with the registermap, there seems to be no issue with the registers that you are accessing.
Just to check with you on the following:
1. Just wonder if the "Enable capability registers" and "Enable control and status registers" under the Optional Reconfiguration Logic tab are checked in the fPLL IP core during instantiation?
2. If after performing #1, similar problem persists. Would you mind to help performing a Modelsim simulation to check on the functional behavior to see if the observation is consistent?
- IMura5 years ago
Terima kasih lah, after enabling those options, now everything works as expected.
