fPLL Arria10 powerdown does nothing
- 5 years ago
Thanks for your update. Regarding your latest observation on the PLL powerdown, as I check with the registermap, there seems to be no issue with the registers that you are accessing.
Just to check with you on the following:
1. Just wonder if the "Enable capability registers" and "Enable control and status registers" under the Optional Reconfiguration Logic tab are checked in the fPLL IP core during instantiation?
2. If after performing #1, similar problem persists. Would you mind to help performing a Modelsim simulation to check on the functional behavior to see if the observation is consistent?
Sorry for the delay. Yes, you are right. You need to enable the dynamic reconfiguration and manual write to the AVMM registers. You may refer to "Fractional PLL Recalibration" in the A10 XCVR PHY user guide for further details on the registers to write to.
I tried following the "7.5.2. Fractional PLL Recalibration " in the A10 XCVR PHY UG but it's very confusing.
First of all, by enabling the 'dynamic reconfiguration' on the fPLL, there is the avl mm bus with 10-bit address and 32-bit data. Are the addresses byte addresses or word addresses?
Because looking at the a10_registermap.xlsx (below is the excerpt), the addresses are not multiple of 4 which makes me think that they are word addresses? I can't seem to read and write to the fPLL and see anything. for example, looking at the signaltap locked output, i know that the fpll is locked but reading the "pll_locked" register, it just stays '0'.
How can I access these registers correctly then?
- IMura5 years ago
Hi again,
I finally figured out that the "7.5.2. Fractional PLL Recalibration " in the A10 XCVR PHY UG steps use byte addressing and I seem to be able to recalibrate the fPLL (the cal_is_busy signal can finally be toggled).
However I still don't know why the a10_registermap.xlsx doesn't have the same offset addresses for the fPLL. Why aren't they the same?
