IMura's avatar
IMura
5 years ago
fPLL Arria10 powerdown does nothing
Hello, I instantiated an fPLL in the transceiver mode as I am using with the JESD204b IP. I noticed that the fPLL can't seem to be "reset" once the FPGA has been configured. Looking at the signalta...
  • CheepinC_altera's avatar
    5 years ago
    Thanks for your update. Regarding your latest observation on the PLL powerdown, as I check with the registermap, there seems to be no issue with the registers that you are accessing.
    Just to check with you on the following:
    1. Just wonder if the "Enable capability registers" and "Enable control and status registers" under the Optional Reconfiguration Logic tab are checked in the fPLL IP core during instantiation?
    2. If after performing #1, similar problem persists. Would you mind to help performing a Modelsim simulation to check on the functional behavior to see if the observation is consistent?
