ArcticRain
3 years agoFP_FUNCTIONS IP Pipelined?
Trying to use the Multiply and Addition functions out of the FP_FUNCTIONS IP. It is clear what the latency through the IP is for a given operation. However, it isn't clear if the operations are pi...
- 3 years ago
Yes, FP_FUNCTIONS IP is pipelined. The waveforms of FP_FUNCTIONS IP with no latency and latency of 2 are attached below for your reference.
Sheng
FvM
3 years agoHello,
"However, it isn't clear if the operations are pipelined such that I can feed inputs in on every clock cycle and expect outputs on every clock cycle the latency number of cycles later. "
Yes that's how pipelining works, definitely also Intel float IP.
Frank
Frank
