StefanoC
3 years agofloat128 floating point IP operations
Hi all,
I noticed that among the parameters of the IP library one can achieve float arithmetic with float32 and float64, but that's it, 64 seems the maximum number of bits possible. Is there anothe...
ShengN_altera
3 years agoHi,
Definitely, that'll be the same approach work with the following code above without the ALTERA floating point library as long as the ALTERA library is not being used.
Sheng
