float128 floating point IP operations
Quartus will not automatically infer Altera/Intel IP as long as the IP is not being used. The IP core module will not be called out if IP is not used. Generally, only those logic, LUT, register, primitive, RAM or etc will be inferred based on the custom design.
Sheng
- StefanoC3 years ago
Thanks, I am getting the picture.. sorry just one last clarification. In the function above you mentioned it can be synthesized either with "my custom code or use Intel IP", by custom code you mean an additional library I would develop or just those few lines would overload the operators +, - *, sqrt to work with floating point? If so I would guess they would consume a large number of LUTs? However it's a good news.
Would the same approach work with the following without the ALTERA floating point library?
signal trial1, trial2 : float64
begin
trial2 <= sqrt(trial2)
